Zum Hauptinhalt wechseln
Gateway M-2626u RAM Replacement
Was du brauchst
  1. Gateway M-2626u RAM  Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: Schritt 2, Bild 1 von 3 Gateway M-2626u RAM  Replacement: Schritt 2, Bild 2 von 3 Gateway M-2626u RAM  Replacement: Schritt 2, Bild 3 von 3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: Schritt 3, Bild 1 von 2 Gateway M-2626u RAM  Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: Schritt 4, Bild 1 von 2 Gateway M-2626u RAM  Replacement: Schritt 4, Bild 2 von 2
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: Schritt 5, Bild 1 von 1
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: Schritt 6, Bild 1 von 2 Gateway M-2626u RAM  Replacement: Schritt 6, Bild 2 von 2
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Abschluss
Tanya Jain
317 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
2 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 160
