Einleitung
The RAM in this laptop can be accessed easily with very little disassembly. There are two slots that both accept PC2-5300S RAM.
Was du brauchst
Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
Firmly pull the battery outwards and away from the laptop.
Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
Repeat the same process for the lower RAM module.
