Zum Hauptinhalt wechseln
Gateway MA6 Laptop RAM Replacement
Was du brauchst
  1. Gateway MA6 Laptop RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: Schritt 2, Bild 1 von 3 Gateway MA6 Laptop RAM Replacement: Schritt 2, Bild 2 von 3 Gateway MA6 Laptop RAM Replacement: Schritt 2, Bild 3 von 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Gateway MA6 Laptop RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: Schritt 4, Bild 1 von 2 Gateway MA6 Laptop RAM Replacement: Schritt 4, Bild 2 von 2
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: Schritt 5, Bild 1 von 3 Gateway MA6 Laptop RAM Replacement: Schritt 5, Bild 2 von 3 Gateway MA6 Laptop RAM Replacement: Schritt 5, Bild 3 von 3
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: Schritt 6, Bild 1 von 2 Gateway MA6 Laptop RAM Replacement: Schritt 6, Bild 2 von 2
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
Abschluss
Cal Poly, Team 6-2, Forte Spring 2014 Mitglied von Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 1,176
