Zum Hauptinhalt wechseln
Gateway MA6 Laptop Wireless Card Replacement
Was du brauchst
  1. Gateway MA6 Laptop Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Wireless Card Replacement: Schritt 2, Bild 1 von 3 Gateway MA6 Laptop Wireless Card Replacement: Schritt 2, Bild 2 von 3 Gateway MA6 Laptop Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: Schritt 3, Bild 1 von 2 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: Schritt 3, Bild 2 von 2
    • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
    • The screw will remain in the backplate.
    • Lift upwards on the back plate to remove it.
  4. Gateway MA6 Laptop Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
  5. Gateway MA6 Laptop Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the 2 mm Phillips #0 screw.
    • The card will lift itself up 30° after the screw has been removed.
  6. Gateway MA6 Laptop Wireless Card Replacement: Schritt 6, Bild 1 von 2 Gateway MA6 Laptop Wireless Card Replacement: Schritt 6, Bild 2 von 2
    • Hold the WiFi card on both sides and pull outwards to remove it.
Abschluss
Cal Poly, Team 6-2, Forte Spring 2014 Mitglied von Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 774
