Zum Hauptinhalt wechseln
Gateway MA7 CD/DVD Drive Replacement
Was du brauchst
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: Schritt 2, Bild 1 von 2 Gateway MA7 CD/DVD Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: Schritt 3, Bild 1 von 3 Gateway MA7 CD/DVD Drive Replacement: Schritt 3, Bild 2 von 3 Gateway MA7 CD/DVD Drive Replacement: Schritt 3, Bild 3 von 3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: Schritt 4, Bild 1 von 2 Gateway MA7 CD/DVD Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: Schritt 5, Bild 1 von 1
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: Schritt 6, Bild 1 von 3 Gateway MA7 CD/DVD Drive Replacement: Schritt 6, Bild 2 von 3 Gateway MA7 CD/DVD Drive Replacement: Schritt 6, Bild 3 von 3
    • Once the drive has been pried out, you can pull the CD drive out.
Abschluss
Tim Rose
392 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S6G2
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 470
