Einleitung
More Random Access Memory (RAM) allows the laptop to run more programs simultaneously, and speed up certain processes. The Gateway MA 7 takes PC2-4200 DDR2 533Mhz 200PIN SODIMM RAM.
Was du brauchst
Push the locking tab over to the right away from the battery to unlock it from the laptop.
Hold the additional locking tab to the left while pulling out the battery.
Remove the following screws securing the plastic panel from the bottom of the laptop:
Seven 6 mm Phillips #0
Pull upwards on the top of the plastic panel to remove it.
With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
Push the two metal tabs (holding the module in place) apart in order to release it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
