Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This step-by-step guide illustrates how to replace the CD drive on the Gateway MD2614u.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the circled screw.
    • Locate the circled screw.
    • Carefully unscrew, making sure not to strip out the screw.
  2. Use any tool with a flat edge in order to pry out the CD-Drive, preferably a plastic opening tool.
    • Use any tool with a flat edge in order to pry out the CD-Drive, preferably a plastic opening tool.
  3. Once the CD drive has been pried out enough, you can pull it out without damaging the other components.
    • Once the CD drive has been pried out enough, you can pull it out without damaging the other components.
Abschluss
Nelson
201 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 261
