Was du brauchst
The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
Fast fertig!
Abschluss
