Einleitung
If a key on your laptop is damaged, replacing it is a short and simple process. All you need to do is open your laptop and use your finger to pop off the key.
Using your fingernail, apply pressure upward from underneath the key to pry it loose from its bearings.
Eine weitere Person hat diese Anleitung absolviert.
