Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If a key on your laptop is damaged, replacing it is a short and simple process. All you need to do is open your laptop and use your finger to pop off the key.
  1. Place the laptop so the top cover is facing up.
    • Place the laptop so the top cover is facing up.
  2. Open the laptop with the display facing you.
    • Open the laptop with the display facing you.
  3. Using your fingernail, apply pressure upward from underneath the key to pry it loose from its bearings.
    • Using your fingernail, apply pressure upward from underneath the key to pry it loose from its bearings.
Abschluss
Toni Pipes
318 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-31, Regan Fall 2010 Mitglied von Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 4,061
