Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
You will use the fan repair guide to get to the CPU. Then, you will use the lock to remove the CPU.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the laptop so the back cover is facing up.
    • Place the laptop so the back cover is facing up.
  2. Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Lift off the cover.
    • Lift off the cover.
  4. Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. The fan is permanently attached to the silver heat sink next to the RAM.
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Pull the fan and heat sink toward you at a 20 degree angle upward.
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
    • The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
    • You will hear a click as the lock unlocks.
  9. Place your fingers on opposite edges of the green card.
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Toni Pipes
318 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-31, Regan Fall 2010 Mitglied von Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Mitglieder
14 Anleitungen geschrieben
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 6,834
