Einleitung
This guide shows the user how to properly remove the keyboard from the Gateway MS2370 Laptop.
Was du brauchst
Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
