Zum Hauptinhalt wechseln
Gateway MS2370 Screen Replacement
Was du brauchst
  1. Gateway MS2370 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: Schritt 2, Bild 1 von 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: Schritt 4, Bild 1 von 1
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: Schritt 5, Bild 1 von 2 Gateway MS2370 Screen Replacement: Schritt 5, Bild 2 von 2
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: Schritt 6, Bild 1 von 1
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: Schritt 9, Bild 1 von 3 Gateway MS2370 Screen Replacement: Schritt 9, Bild 2 von 3 Gateway MS2370 Screen Replacement: Schritt 9, Bild 3 von 3
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: Schritt 10, Bild 1 von 2 Gateway MS2370 Screen Replacement: Schritt 10, Bild 2 von 2
    • Slowly remove the screen from the laptop.
Abschluss
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G5, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 648
