Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Ensure device is powered off and unplugged from a power source. Place the device upside down.
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
Abschluss
Jared Lotfi
286 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 161
