Was du brauchst
Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
Remove 5 6.0 mm Phillip #00 screws from under cover.
Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
First flip open the flap covering the ribbon using a spudger or fingernail.
Second gently pull the ribbon away from the port.
Grasp the plastic placeholder firmly and slide it out of the computer.
When inserting replacement optical drive, use the port at the back left of the open space.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
