Einleitung
So your laptop won't download data when you plug in a USB device? The problem is most likely a non-functioning USB port, and you'll have to replace it. This guide will provide you with the steps you need in order to replace your old USB port with a new one.
Was du brauchst
Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
Remove 5 6.0 mm Phillip #00 screws from under cover.
Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
First flip open the flap covering the ribbon using a spudger or fingernail.
Second gently pull the ribbon away from the port.
Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
