Zum Hauptinhalt wechseln
Gateway NE52214U Fan Replacement
Was du brauchst
  1. Gateway NE52214U Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Fan Replacement: Schritt 2, Bild 1 von 2 Gateway NE52214U Fan Replacement: Schritt 2, Bild 2 von 2
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Fan Replacement, Upper Case: Schritt 3, Bild 1 von 2 Gateway NE52214U Fan Replacement, Upper Case: Schritt 3, Bild 2 von 2
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Fan Replacement: Schritt 4, Bild 1 von 1
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Fan Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Fan Replacement: Schritt 7, Bild 1 von 2 Gateway NE52214U Fan Replacement: Schritt 7, Bild 2 von 2
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
  8. Gateway NE52214U Fan Replacement, Fan: Schritt 8, Bild 1 von 1
    • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
  9. Gateway NE52214U Fan Replacement: Schritt 9, Bild 1 von 2 Gateway NE52214U Fan Replacement: Schritt 9, Bild 2 von 2
    • Gently lift the fan and disconnect the fan from the motherboard.
    • Remove the fan from the device.
Abschluss
Kelsey Rodrigues
495 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 176
