Einleitung
Removing the upper case of the laptop is necessary if the case is significantly damaged since it is essentially to protecting the laptop's internal components. Upper case removal is also a necessary preliminary step for replacing many of these internal components. Remove battery before upper cover case.
Was du brauchst
Slide the tab to the left and hold the tab there.
While holding down the sliding tab, remove the battery from the device.
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
