Zum Hauptinhalt wechseln
Gateway NE56R27u Screen Replacement
Was du brauchst
  1. Gateway NE56R27u Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Gateway NE56R27u Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: Schritt 2, Bild 1 von 2 Gateway NE56R27u Screen Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: Schritt 3, Bild 1 von 3 Gateway NE56R27u Screen Replacement, Screen: Schritt 3, Bild 2 von 3 Gateway NE56R27u Screen Replacement, Screen: Schritt 3, Bild 3 von 3
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: Schritt 4, Bild 1 von 3 Gateway NE56R27u Screen Replacement: Schritt 4, Bild 2 von 3 Gateway NE56R27u Screen Replacement: Schritt 4, Bild 3 von 3
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: Schritt 5, Bild 1 von 2 Gateway NE56R27u Screen Replacement: Schritt 5, Bild 2 von 2
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: Schritt 6, Bild 1 von 3 Gateway NE56R27u Screen Replacement: Schritt 6, Bild 2 von 3 Gateway NE56R27u Screen Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: Schritt 7, Bild 1 von 2 Gateway NE56R27u Screen Replacement: Schritt 7, Bild 2 von 2
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: Schritt 8, Bild 1 von 2 Gateway NE56R27u Screen Replacement: Schritt 8, Bild 2 von 2
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: Schritt 9, Bild 1 von 2 Gateway NE56R27u Screen Replacement: Schritt 9, Bild 2 von 2
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 213
