Zum Hauptinhalt wechseln
Gateway NV52 Hard Drive Replacement
Was du brauchst
  1. Gateway NV52 Hard Drive Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: Schritt 3, Bild 1 von 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Gateway NV52 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Gateway NV52 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
  5. Gateway NV52 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
  6. Gateway NV52 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
Abschluss
Irma Marin
608 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-24, Regan Spring 2014 Mitglied von Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 3,523
