Einleitung
The Optical Disc Drive is not required to be taken out to have more access to the other components of the laptop.
Was du brauchst
Remove the single 3/16" screw with the Phillips #0 Screwdriver that secures the Optical Drive.
Slightly wiggle the Optical Drive from the laptop using the Heavy Duty Spudger.
Using your hands, gently slide the Optical Drive out of the slot.
Set the Optical Drive in a safe designated area.
Eine weitere Person hat diese Anleitung absolviert.
