Zum Hauptinhalt wechseln
Gateway NV52 WiFi Card Replacement
Was du brauchst
  1. Gateway NV52 WiFi Card Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 WiFi Card Replacement: Schritt 2, Bild 1 von 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 WiFi Card Replacement, WiFi Card: Schritt 3, Bild 1 von 1
    • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
  4. Gateway NV52 WiFi Card Replacement: Schritt 4, Bild 1 von 1
    • Locate the black and white cables attached to the WiFi card.
    • Gently wiggle the black cable until it detaches from the WiFi card.
    • Repeat the previous step for the white cable.
  5. Gateway NV52 WiFi Card Replacement: Schritt 5, Bild 1 von 1
    • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
Abschluss
Ruben
298 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 7-24, Regan Spring 2014 Mitglied von Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,272
