Einleitung
If your laptop screen is not functioning properly, use this guide to replace the display. This is a difficult repair that requires the laptop to be nearly completely disassembled. This level of disassembly requires handling multiple fragile components, so caution should be used.
Was du brauchst
Push the battery slider to the other side. This will automatically eject the battery.
You can now remove the battery
Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
There are 6 small clips that holding the top row of the keyboard in place.
To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
Once the keyboard is loose, slowly lift the keyboard away from the laptop.
There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
After the fastener is loose, gently disconnect the cable.
Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
Use a plastic pry tool to disconnect the single pinned connector.
Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
The display is now fully disconnected.
Eine weitere Person hat diese Anleitung absolviert.
