Zum Hauptinhalt wechseln
Gateway NV55C49u USB Port Replacement
Was du brauchst
  1. Gateway NV55C49u USB Port Replacement, USB Port: Schritt 1, Bild 1 von 1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u USB Port Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u USB Port Replacement: Schritt 3, Bild 1 von 2 Gateway NV55C49u USB Port Replacement: Schritt 3, Bild 2 von 2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u USB Port Replacement: Schritt 4, Bild 1 von 2 Gateway NV55C49u USB Port Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  5. Gateway NV55C49u USB Port Replacement: Schritt 5, Bild 1 von 1
    • Remove all nine 6.0mm #00 Phillips screws from the back of the laptop.
  6. Gateway NV55C49u USB Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u USB Port Replacement: Schritt 7, Bild 1 von 1
    • Flip the laptop over so that the cover faces you.
    • Open the laptop so you can see the keyboard.
  8. Gateway NV55C49u USB Port Replacement: Schritt 8, Bild 1 von 1
    • Push in the tabs that are located around the keyboard using the triangle scalpel tool.
    • This should release the keyboard so it can be pulled up
  9. Gateway NV55C49u USB Port Replacement: Schritt 9, Bild 1 von 1
    • Slowly lift up the keyboard away from the laptop.
    • Push on the sides on the black ribbon cable using 2 plastic opening tools to release it.
  10. Gateway NV55C49u USB Port Replacement: Schritt 10, Bild 1 von 1
    • Remove the 3 ribbon cables that are showing using the plastic opening tools.
  11. Gateway NV55C49u USB Port Replacement: Schritt 11, Bild 1 von 2 Gateway NV55C49u USB Port Replacement: Schritt 11, Bild 2 von 2
    • Remove the disk drive cover on the right side of the laptop using the plastic opening tool.
    • Slide the disc drive out of its compartment, using the metal spudger.
  12. Gateway NV55C49u USB Port Replacement: Schritt 12, Bild 1 von 1
    • Lift the face plate off the laptop body.
  13. Gateway NV55C49u USB Port Replacement: Schritt 13, Bild 1 von 1
    • Remove the 6.0 mm Phillips #00 screw that holds in the USB port.
  14. Gateway NV55C49u USB Port Replacement: Schritt 14, Bild 1 von 1
    • Push on the sides of the white ribbon cable that is attached to the motherboard using the 2 plastic opening tools to release it.
Abschluss
Micaela
329 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 730
