Einleitung
The hard drive is a component that will act as storage for your device. This guide will go over how to remove and replace the hard drive for the P-6831FX.
Was du brauchst
Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
Gently pull the cover away from the device.
Set the cover aside for now, until reassembly.
Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
Eine weitere Person hat diese Anleitung absolviert.
