Einleitung
This guide will show you how to replace your laptop's hard drive.
Was du brauchst
Unscrew all .5mm screws from the back rectangular panel. Use a J0 screwdriver.
Firmly press with your hand on the silver surface and pull back, dislodging the hard drive from its port.
Remove the four 1.2mm screws attaching the case to the hard drive. Use the same J0 screwdriver.
Fast fertig!
Abschluss
