Einleitung
This guide will show you to how remove your laptop's keyboard, which may be necessary if the keys stop working.
Was du brauchst
Remove the battery.
Flip the switch to the right.
Pull the battery out.
Remove the 2mm screws on the backside of the laptop using a J0 screwdriver.
Then remove the panels from the back of the laptop.
Using a pair of tweezers, your fingers, or a screw driver, carefully dig into the laptop cover and apply force to pop it out.
Do this on the right and left sides of the cover.
