Zum Hauptinhalt wechseln
Gateway SA1 Hard Drive Replacement
Was du brauchst
  1. Gateway SA1 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Gateway SA1 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Gateway SA1 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 24-20, Regan Spring 2010 Mitglied von Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 14,023
