Zum Hauptinhalt wechseln
Gateway SA1 RAM Replacement
Was du brauchst
  1. Gateway SA1 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Gateway SA1 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
  4. Gateway SA1 RAM Replacement: Schritt 4, Bild 1 von 2 Gateway SA1 RAM Replacement: Schritt 4, Bild 2 von 2
    • Lift and remove the cover using the spudger.
  5. Gateway SA1 RAM Replacement: Schritt 5, Bild 1 von 2 Gateway SA1 RAM Replacement: Schritt 5, Bild 2 von 2
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
  6. Gateway SA1 RAM Replacement: Schritt 6, Bild 1 von 1
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 24-20, Regan Spring 2010 Mitglied von Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 5,618
