Zum Hauptinhalt wechseln
Gateway SA1 Wireless Card Replacement
Was du brauchst
  1. Gateway SA1 Wireless Card Replacement, Wireless Card: Schritt 1, Bild 1 von 1
    • The first thing you need to do is remove the panel concealing the wireless card, by taking out the screws.
  2. Gateway SA1 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Locate the wireless card on the right side of the now removed panel.
  3. Gateway SA1 Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Remove the screws in the two possible locations.
  4. Gateway SA1 Wireless Card Replacement: Schritt 4, Bild 1 von 1
    • After removing the screws, gently pull upwards on the end of the wireless card until it is angled as shown.
  5. Gateway SA1 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Pull the card diretly outward from its socket, all while being mindful of the connected wires.
    • Remove the wired connections by gently pulling them diretly away from the card. Please remember where each one was connected, it will be useful for reconnecting
    • Reconnect wires to new wireless card and screw back into place.
Abschluss
Shawn Cabral
463 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-4, Cichon Spring 2014 Mitglied von UMass Dartmouth, Team 5-4, Cichon Spring 2014
UMASSD-CICHON-S14S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 667
