Zum Hauptinhalt wechseln
Gateway Solo 1200 RAM Replacement
Was du brauchst
  1. Gateway Solo 1200  RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Gateway Solo 1200  RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Gateway Solo 1200  RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200  RAM Replacement, RAM: Schritt 2, Bild 1 von 1
    • Locate the RAM compartment on the underside of the laptop near the center.
  3. Gateway Solo 1200  RAM Replacement: Schritt 3, Bild 1 von 2 Gateway Solo 1200  RAM Replacement: Schritt 3, Bild 2 von 2
    • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
    • Once unscrewed, lift off the compartment cover.
  4. Gateway Solo 1200  RAM Replacement: Schritt 4, Bild 1 von 1
    • Press the silver retention levers on either side of the RAM away from the center of the RAM.
    • The RAM stick will pop up after the retention levers are released.
  5. Gateway Solo 1200  RAM Replacement: Schritt 5, Bild 1 von 1
    • Pull the RAM stick out of its socket.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Addison
2.967 Reputation
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 773
