Einleitung
This repair is needed in situations where your keyboard stops working. If you have checked that all the keys are properly seated and that there is nothing blocking key movement, replacing the keyboard should correct the issue.
Was du brauchst
Turn the laptop upside down and position it as shown in the image.
Slide the locking switch towards the open lock picture.
Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
Once the laptop is disengaged, completely remove the battery from the laptop.
Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
Remove the 4mm Phillips #0 screw that secures the keyboard.
Reposition the laptop so that it is upright with the display open.
Carefully pry up on the right and left sides of the speaker cover panel.
Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
Pull on the cord connecting the keyboard to the computer until it slides out.
2 weitere Personen haben diese Anleitung absolviert.
