Einleitung
The batteries power the car and allow it to run. If it isn't running, try using the following steps to replace the batteries.
Was du brauchst
Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
Gently lift the battery cover from the car to expose the batteries.
Fast fertig!
Abschluss
