Zum Hauptinhalt wechseln
GeeksPhone Keon Camera Replacement
Was du brauchst
  1. GeeksPhone Keon  Camera Replacement, Battery: Schritt 1, Bild 1 von 2 GeeksPhone Keon  Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon  Camera Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon  Camera Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon  Camera Replacement, Back Plate: Schritt 4, Bild 1 von 2 GeeksPhone Keon  Camera Replacement, Back Plate: Schritt 4, Bild 2 von 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon  Camera Replacement: Schritt 5, Bild 1 von 2 GeeksPhone Keon  Camera Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon  Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon  Camera Replacement: Schritt 7, Bild 1 von 3 GeeksPhone Keon  Camera Replacement: Schritt 7, Bild 2 von 3 GeeksPhone Keon  Camera Replacement: Schritt 7, Bild 3 von 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon  Camera Replacement: Schritt 8, Bild 1 von 2 GeeksPhone Keon  Camera Replacement: Schritt 8, Bild 2 von 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon  Camera Replacement, Camera: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Lift the retaining flap on camera's ZIF connector.
    • Pull the ribbon cable away with tweezers.
  10. GeeksPhone Keon  Camera Replacement: Schritt 10, Bild 1 von 3 GeeksPhone Keon  Camera Replacement: Schritt 10, Bild 2 von 3 GeeksPhone Keon  Camera Replacement: Schritt 10, Bild 3 von 3
    • Carefully wiggle the camera away from the device.
Abschluss
To reassemble your device, follow these instructions in reverse order; but remember, the new camera must be glued back in place where the old one was removed.
Bryan Bittner
167 Reputation
1 Anleitung geschrieben
USF Tampa, Team 3-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 249
