Zum Hauptinhalt wechseln
GeeksPhone Keon Battery Replacement
Was du brauchst
  1. GeeksPhone Keon Battery Replacement, Battery: Schritt 1, Bild 1 von 2 GeeksPhone Keon Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Battery Replacement: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 3-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Mitglieder
12 Anleitungen geschrieben
4 Kommentare
Newer Keon model has user replaceable battery GP-BA002
gintasdx - Antwort
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
gintasdx - Antwort
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - Antwort
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 558
