Zum Hauptinhalt wechseln
General Disassembly LG VX8560
Was du brauchst
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: Schritt 1, Bild 1 von 1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: Schritt 2, Bild 1 von 1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: Schritt 3, Bild 1 von 1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: Schritt 4, Bild 1 von 1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: Schritt 5, Bild 1 von 2 General Disassembly LG VX8560: Schritt 5, Bild 2 von 2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: Schritt 6, Bild 1 von 1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jack Foley
37 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-62, Johann Spring 2013 Mitglied von Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 11
Insgesamt: 450
