Einleitung
If you memory card is corrupt or not working, this guide will demonstrate how to locate the memory card and replace it with a new one.
Was du brauchst
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
After the screws are removed, pull the front casing up and away from the camera.
Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
The last part of the casing to disconnect is the back that houses the LCD screen.
The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
Using the Phillips precision screwdriver with the PH000 Phillips bit, remove the two 1.5mm screws.
With a firm grip towards the bottom of the control board, gently pull away from the camera, removing the ribbon from the connector.
Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
Locate the memory card slot in the bottom right corner of the camera.
Using a plastic opening tool, gently pry up on the edges of the bottom right corner of the control board.
Gently raise the lower right corner of the circuit board by prying upwards with an opening tool.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of precision tweezers, slide one end under the memory card.
Firmly grip the memory card with the tweezers and pull directly outwards.
