Einleitung
This guide is to replace the speaker located inside the phone base
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
Remove the phone cord screw cap.
Unscrew the 7.5mm screw.
Remove the screw cap.
Remove the cord from the phone base.
Remove the Volume Dial by gently grasping the dial and pulling away from the base.
Remove the 6 screws from the base shell.
Remove the 3 12mm screws with the Philips head #1 screw driver.
Remove the 3 18mm screws with the Philips head #1 screw driver.
Slightly pull out speaker.
Cut wire as close as speaker as possible with wire cutters.
Remove speaker.
Solder on the new speaker.
Please visit How to Solder to learn more about soldering.
