Zum Hauptinhalt wechseln
General Electric Telephone 2-9710A Base Speaker Replacement
Was du brauchst
  1. General Electric Telephone 2-9710A Base Speaker Replacement, Phone Cord: Schritt 1, Bild 1 von 2 General Electric Telephone 2-9710A Base Speaker Replacement, Phone Cord: Schritt 1, Bild 2 von 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 2, Bild 1 von 3 General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 2, Bild 2 von 3 General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. General Electric Telephone 2-9710A Base Speaker Replacement, 9V Base Battery: Schritt 3, Bild 1 von 2 General Electric Telephone 2-9710A Base Speaker Replacement, 9V Base Battery: Schritt 3, Bild 2 von 2
    • Remove the battery compartment door (located on the bottom of the radio) by applying thumb pressure to the area indicated on the battery door.
    • Slide the door off of the battery compartment.
    • Remove the battery from the phone.
  4. General Electric Telephone 2-9710A Base Speaker Replacement, Remove Volume Dial: Schritt 4, Bild 1 von 2 General Electric Telephone 2-9710A Base Speaker Replacement, Remove Volume Dial: Schritt 4, Bild 2 von 2
    • Ensure the phone is unplugged from the phone jack and the electrical source.
    • Locate the volume dial on the right side of the telephone.
    • Remove the volume dial by gently grasping it and pulling it away from the base.
  5. General Electric Telephone 2-9710A Base Speaker Replacement, Remove Screws on the Back: Schritt 5, Bild 1 von 1
    • Remove the three 12 mm screws with a Phillips #1 screwdriver.
    • Remove the three 18 mm screws with a Phillips #1 screwdriver.
  6. General Electric Telephone 2-9710A Base Speaker Replacement, Pry the Back Off: Schritt 6, Bild 1 von 2 General Electric Telephone 2-9710A Base Speaker Replacement, Pry the Back Off: Schritt 6, Bild 2 von 2
    • Pry off the base shell using a plastic opener tool.
    • Set the shell aside.
    • You now have access to the internal components of the General Electric Telephone 2-9710A.
  7. General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: Schritt 7, Bild 1 von 3 General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: Schritt 7, Bild 2 von 3 General Electric Telephone 2-9710A Base Speaker Replacement, Base Speaker: Schritt 7, Bild 3 von 3
    • Slightly pull out speaker.
    • Cut wire as close as speaker as possible with wire cutters.
    • Remove speaker.
  8. General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 8, Bild 1 von 3 General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 8, Bild 2 von 3 General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 8, Bild 3 von 3
    • Strip the wire half an inch using wire strippers for a 24 gauge wire.
  9. General Electric Telephone 2-9710A Base Speaker Replacement: Schritt 9, Bild 1 von 1
    • Solder on the new speaker.
    • Please visit How to Solder to learn more about soldering.
Abschluss
Cal Poly, Team 16-59, Forte Fall 2012 Mitglied von Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 1,415
