Einleitung
Use this guide to replace the reverse switch in a General Pipe Cleaners Drain Cleaner PMEBO 2016.
Was du brauchst
Use a Phillips #2 driver to remove the two screws securing the control box cover.
Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
Squeeze the tabs on either side of the reverse switch connector.
Pull the two halves of the connector apart to disconnect it.
Pull the white cable straight off of its spade connector on the power switch diaphragm.
Pull the black cable straight off of its spade connector on the power switch diaphragm.
Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
