Einleitung
Use this guide to replace the upper feed roller bearing in a General Pipe Cleaners Drain Cleaner PMEBO 2016.
Was du brauchst
Use your hand to unscrew and remove the feed pressure knob.
Use a 1/4 inch socket wrench to remove the three bolts securing the feed roller holder plate.
Use pliers to lift out and remove the pressure spring plate.
Lift out and remove the pressure spring.
Remove the upper feed roller assembly, including the fiber disks on either side of it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
