Einleitung
Use this guide to replace the cable in a General Wire Drain Cleaner RSVD 2014.
Was du brauchst
Slide the rubber cable cover off of the end of the cable.
Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
Slide the plastic cable container out of the metal container back.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
