Zum Hauptinhalt wechseln
Generic TV Remote IR LED Replacement
Was du brauchst
  1. Generic TV Remote IR LED Replacement, IR LED: Schritt 1, Bild 1 von 2 Generic TV Remote IR LED Replacement, IR LED: Schritt 1, Bild 2 von 2
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
  2. Generic TV Remote IR LED Replacement: Schritt 2, Bild 1 von 3 Generic TV Remote IR LED Replacement: Schritt 2, Bild 2 von 3 Generic TV Remote IR LED Replacement: Schritt 2, Bild 3 von 3
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
  3. Generic TV Remote IR LED Replacement: Schritt 3, Bild 1 von 1
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
  4. Generic TV Remote IR LED Replacement: Schritt 4, Bild 1 von 1
    • Desolder the broken LED using a soldering iron and desoldering braid.
  5. Generic TV Remote IR LED Replacement: Schritt 5, Bild 1 von 1
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
  6. Generic TV Remote IR LED Replacement: Schritt 6, Bild 1 von 3 Generic TV Remote IR LED Replacement: Schritt 6, Bild 2 von 3 Generic TV Remote IR LED Replacement: Schritt 6, Bild 3 von 3
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
  7. Generic TV Remote IR LED Replacement: Schritt 7, Bild 1 von 1
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 125
Insgesamt: 12,772
