Was du brauchst
Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
Make sure any and all cables are separated from the fire box (the bottom of the grill).
Slot the panel back on the grill and then push downward.
Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
