Zum Hauptinhalt wechseln
George Foreman GR-20 Disassembly
Was du brauchst
  1. George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: Schritt 1, Bild 1 von 2 George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: Schritt 1, Bild 2 von 2
    • Open the grill and remove the two Phillips #2 screws from the top lid.
  2. George Foreman GR-20 Disassembly: Schritt 2, Bild 1 von 3 George Foreman GR-20 Disassembly: Schritt 2, Bild 2 von 3 George Foreman GR-20 Disassembly: Schritt 2, Bild 3 von 3
    • Using a pick, peel off the model number sticker to expose the two screws underneath. Remove these screws using a Phillips #2 screwdriver.
  3. George Foreman GR-20 Disassembly: Schritt 3, Bild 1 von 2 George Foreman GR-20 Disassembly: Schritt 3, Bild 2 von 2
    • Remove the Phillips #2 screw from the orange tab.
    • Detach the top lid from the bottom of the grill.
  4. George Foreman GR-20 Disassembly: Schritt 4, Bild 1 von 2 George Foreman GR-20 Disassembly: Schritt 4, Bild 2 von 2
    • To measure the resistance of the heating coil, disconnect the blue wire from the heating element.
  5. George Foreman GR-20 Disassembly: Schritt 5, Bild 1 von 1
    • To access the underside of the grill, flip the grill over and remove the rubber bottoms of the two front feet to expose the screws.
  6. George Foreman GR-20 Disassembly: Schritt 6, Bild 1 von 1
    • Remove the two screws using a Phillips #2 screwdriver.
  7. George Foreman GR-20 Disassembly: Schritt 7, Bild 1 von 2 George Foreman GR-20 Disassembly: Schritt 7, Bild 2 von 2
    • Remove the two Phillips #2 screws in front of the two back feet.
  8. George Foreman GR-20 Disassembly: Schritt 8, Bild 1 von 2 George Foreman GR-20 Disassembly: Schritt 8, Bild 2 von 2
    • To remove the power cord from the device, remove the two Phillips #2 screws keeping the power cord and the blue and white wires connected.
  9. George Foreman GR-20 Disassembly: Schritt 9, Bild 1 von 1
    • After removing the screws, slide the blue and white wires out through the gap.
    • You will now have access to the underside of the grill.
  10. George Foreman GR-20 Disassembly: Schritt 10, Bild 1 von 2 George Foreman GR-20 Disassembly: Schritt 10, Bild 2 von 2
    • Remove the two Phillips #2 screws attaching the fuse to the grill.
    • Remove the fuse from the grill.
  11. George Foreman GR-20 Disassembly: Schritt 11, Bild 1 von 1
    • Remove the Phillips #2 screw from the white wire.
    • Remove the white wire from the grill.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thanks to this, I've been able to fix my George Foreman grill! Absolute blessing!
OK GGS - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 961
