Einleitung
The disconnection between wires or loose wiring could be a cause for the George Foreman to not heat up to a sufficient temperature to cook. This guide gives step by step instructions and visual aids to help the wire connection to this appliance. With the help of this guide, you will have the confidence that if your grill were to malfunction, a few simple steps will have it up and running again in no time!
Was du brauchst
Remove the plates by pushing down on the black knobs on either side of the plates, top and bottom.
After, pick up and lift the plates off of the appliance.
Remove the 12 Phillips head screws on the bottom plate with a #1 Phillips head screw driver.
After unscrewing the screws, lift off the base plate.
This is where you will see the wires.
Re-establish the disconnected or loose wires by pushing them back into the point of connection.
Push the wires into the connection center on the bottom of the plate until you can't anymore. This is how you know they will not come loose again.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Unable to repair the split cord on my George Foreman small health fit grill model 25800 as the plates are screwed on. Please advise.
