Einleitung
Is your Getac V110 laptop failing to hold a charge? Does it die quickly without being plugged in? If so, a battery replacement is likely the solution. This guide will walk you through the simple process of replacing your Getac V110's battery, getting your laptop back to top performance in no time.
Was du brauchst
Gain access to battery by : Sliding the lock to right.
Folding the lock down.
Move battery strap to right.
With the new battery installed, power up your Getac V110 and enjoy extended use without worrying about running out of juice. If you followed the guide carefully, the replacement process should be quick and painless. Now get back to work with your fully functional laptop!
