Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Proper maintenance of the Giant Reign 2 bicycle includes installation and lubrication of a new headset. This guide will clearly show you how to perform this maintenance quickly and safely, extending the life of your bike.
  1. Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible. Push the axle screw to reveal the axle rod on the other side.
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Pull the wheel from the fork.
    • Pull the wheel from the fork.
  5. Using the 8mm Allen wrench, unscrew 2  (32mm) screws to release the brake calipers from the fork. If necessary use wire cutters to release zip ties attaching cables to the forks.
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
  6. Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam. Using the 4mm Allen wrench, loosen the side screw on both sides. Lift off the handlebar.
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
  7. Slide off the spacers. Lift off the seal. Lift off the seal.
    • Slide off the spacers.
    • Lift off the seal.
  8. Slide the fork out of the casing.
    • Slide the fork out of the casing.
  9. Using your fingers, pry the bearings from the top and bottom of the headset.
    • Using your fingers, pry the bearings from the top and bottom of the headset.
  10. Apply WD-40 to both ends of the headset and bearings.
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
  11. Using your finger, apply all-purpose lube to the bearings and each end of the headset. Insert the bearings into the headset with the beveled side facing into the headset.
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sterling Grande
148 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-14, Amido Fall 2012 Mitglied von Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 18
Insgesamt: 3,606
