Einleitung
Have you lost or broken a wheel spoke? This guide will show you how to replace it.
Was du brauchst
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
Twist and pull off the cap covering the tire valve
Twist off the spacer that holds the valve in place.
Push valve in toward wheel to release air pressure.
Insert one tire lever between the tire and the rim.
Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
Insert a second tire lever next to the first.
Slowly slide one tire lever around the rim until the tire is released from the rim.
Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
Pull brake rotors off both sides of the wheel.
Using a tire lever, push the rim tape aside to reveal the spoke nipple.
Using your fingers, pull off the old spoke nipple.
Insert a new 250mm spoke into the hub.
Align the spoke with the spoke nipple in the rim.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
