Einleitung
The hard drive stores some of the computer's files and has limited space. Replacement of the hard drive is necessary if it is broken or there is no space left.
It may be advantageous to upgrade the hard drive to a Solid State Drive (SSD) as their advantages over a traditional hard drive include: faster load times, longer lasting and more durable, use less power, and are quieter.
Upon opening the laptop casing disconnect the battery to reduce the risk of a power overload. This guide shows how:
Gigabyte P34G Battery Replacement
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds. Additional methods are discussed here:
Was du brauchst
Carefully peel back the two pieces of black tape holding down the cord.
Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
